Disables IPv4 route compression.
vrname | VR or VRF name for which the IP route compression is being disabled. If the VR or VRF name is not specified, route compression is disabled for the VR context from which CLI command is issued. |
Enabled.
Disables IPv4 route compression for a specified VR or VRF.
The following example disables IP route compression:
disable iproute compression
This command was first available in ExtremeXOS 12.0.
Default changed to enabled in ExtremeXOS 15.6.
